NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Mon May 02, 2005 8:25 am
unless your are really good with automotive wiring i would not recommend messing with the wiring going through the spiral cable and to the steering wheel, unless you dont mind setting off explosives in your face. It is very risky to mess with the circuits going into the steering wheel since the air bag,horn ,cruise ,and radio wires all go through that common connector. you screw up with one wire and BANG!!! air bag deploys and you are left with either blindness, torn open face, broken arm or worse death.
Stick with the same year if you buy the wheel so you dont have to screw with the wiring and end up hurting yourself.
