CPS »
https://forums.nicoclub.com/cps-u98655.html
Sun Mar 15, 2009 5:07 pm
I've been working at a Nissan dealer for over 3.5 years and I have never heard of this issue. Like KJSmitty said, overpressurization is the fault of the radiator cap as long as water is flowing smoothly. However, if you've ever put Bars Stop Leak or anything else in the cooling system, then that could be continuously flowing through the system and restricting flow somewhere that the cap can't bleed off the pressure. Say it's caused a restriction on the opposite side of the radiator from the cap. Pressure builds up and the cap can't release it because the pressure on it is not high enough. Pops the radiator. Dealer puts another one in. Stop Leak is still in the system, restricts it again, pop. Repeat.
You never really get Stop Leak out regardless of flushes, because that stuff goes everywhere. It sticks in places but also breaks off in chunks which could be causing your issues.
Another issue would be a blown head gasket, but that is determined by a simple chemical test, which I would guess the dealer has already done to rule that out. In that case you would have cylinder pressure in the cooling system, and the cap cannot bleed off that kind of pressure fast enough. However, you would be experiencing other issues (misfires, loss of gas mileage, hesitation) if the leak was that bad.
I'm with everybody else, take it back to the dealer, or to another dealer for a second opinion. It's not normal.
