i have a nissan micra 1.0s suffering from poor mpg
can anyone help please
Optional Information: Year: 2001Make: NissanModel: micraEngine: 1.0s i have a nissan micra 1.0s 2001 y reg suffering from poor mpg. i used to get close to 100 miles from £10 now i only get around 28 miles from £5. gosh that's bad. i've serviced the car, new oil and oil filter castrol gtx , new spark plugs ngk, new air filter new pcv filter blue print which is located under the air filter. new fuel filter blue print. i have checked the tyre pressure thats fine. i have added stp fuel addative to the petrol. the car now gives off a white cloudy smoke and is spiiting what i think is water from the exhaust. the car is not burning any oil or consuming any coolant water. the engine management light has not come on. i have removed the pollen filter due to poor heat coming through to the cabin. that's ok now since i removed the pollen filter. i have checked if any wheels are seized. There has been no drop in performance at all. the throttle body and air mass flow sensor was changed less than a year ago. i have also had the emissions checked they are fine please help me.
any ideas or suggestions are much appreciated
