Nissan Maxima Wheels on G50 Q45
.::94Q45::.
Car: 1994 Infiniti Q45
I recently purchased a set Nissan Maxima OEM wheels
They are 18x7.5 with an offset of +40
Tires are 225/40/18 but they seem a bit too small for the G50
I was thinking of getting 245/45/18 would this be a good size or what other
size would you guys recommend?
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
I don't like the idea. The Maxima is not a V8 powered car and is probably 500 pounds lighter. I would hold out for some FX of later Q45 rims.
.::94Q45::.
I should consider that...I know the maxima is not as big as a q45 but a 2004 maxima is not small either.
goody90q45
Car: 1992 Infiniti Q45 (sold)
On the other hand...a lot of us are running with G35 wheels with no weight issues. I would thing the Maxi and the G35 are close in weight.
I have 235/50-17 on my Q with plenty of room. I think the 45's are a better choice for you.
Q45man1
Car: 2002 Q45, 1994 Q45
I have the 02Q rims (18x7.5, 35mm offset) installed to my 94Q. 245/45R18 tires is a good choice and also get with min rating of 95 load index. Plenty of tires to choose from and depends on your budget.
Good luck.
.::94Q45::.
Thats what I was thinking a lot of you guys have OEM 350z or G35 wheels which dont have V8's and weight about the same as a Maxima.
So I'll go with 245/45/18
Michelins
BadQ45t
I didn't notice you owned them already :) that is half the battle. What i would consider is going with some XL rated tires. I just put 245/40 19 XL Michelin Pilot Sports in XL 98 load rating. I had a really good set of Bridgestone 050A Pole Positions on there before but were only 94 rated. The side-wall split going over a big bump after only 50% of the tread was gone, so go with the XL for sure...that will make up for any weight issues. I highly recommend that Pilot Sports, they are a little noisy but the handling and confidence the give is unmatched even by my favorite Bridgestones.
