nissan maxima trans trouble codes
daoracle_sentme
Car: 1995 Q45 Infiniti
I thought I would try here to see if I can find the answer to my problem. I'm trying to figure out the code for my q45 after I did the transmission self diagnosis test. I received 3 flashes and then the okay light. no ne can tell em how to decipher that. I did find the nissan codes though are they the same? would three flashes mean TPS ? The nissan codes are below for reference.
NISSAN TCU CODES1st -Vehicle speed sensor(A/T Revolution) circut2nd -Vehicle speed sensor/MTR (at Speedometer)3rd -Throttle position sensor or switch4th -Shift solenoid valve "A"5th -Shift solenoid valve "B"6th -Overrun clutch solenoid Valve7th -Torque converter solenoid valve8th -Fluid temp sensor/ ATCU power source circut9th -Engine speed signal circut10th -Turbine revolution sensor11th -line pressure solenoid sensor
