Nissan Maxima LED domelight install
Troubleshooting, DIY's, How-To's and articles about all Nissan vehicles. Non-vehicle specific "General" How-To and tech information is also here.
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
*NOTE* LED's (light emitting diodes) will only work if the electrical current is "flowing" in the correct direction. If your lights do not work, simply reverse the direction of the LED connector. Do not try to reverse the plug, simply turn the connector 180*
Ok, installation was really easy The front map light popped right in, and was a 2 minute job. Take out your incandescent bulb, and attach the LED connector, as if it were the incandescent bulb. Peel off the 3M™ adhesive backing, and press into place in the center of the fixture. Direct fit.
The center dome installs the same as the map lights.
The door lights are a little more tricky. With a small straight bladed screwdriver (wrapped in a thin cloth) gently pry out the light assembly in the door.
Remove the plug on the back of the light assembly. Then gently remove the lens cover using the small screwdriver.
Remove the incandescent bulb, then insert the LED connector as if it were an incandescent bulb.
Attach the 3M™ adhesive foam to each side of the LED assembly, and attach to the light bracket. I used a thin piece on one side and a thick piece on the other.
Replace lens cover and plug in the wires. Gently push the light back into the door.
Enjoy your newly lit car!
Return to “Nissan Articles”
