szeryk wrote:I am writing to you, in order to receive some technical help concerning my ’97 Nissan Maxima, sedan, 3.0 L, automat. I found your www site on the Internet.
I was trying to get some help from other ( more local) sources but with no success. I am quite desperate right now as my Maxi is “resting” in mechanic garage for more than 4 months
The most recently diagnosis is that computer is damaged and need a replacement. I was looking for that part on the internet unfortunately have no idea which one will run in my Maxi. I attached a photo of the label on my
computer. I would like to ask you to match a proper part with it.
I am writing to you from Poland ( can you imagine that in my country I can get no help?! )
I would be really grateful for your help.
information abot my computer: D2 23710 46U10 A18 F98 E58
Well you probably already know this, but the part that is the nissan part number is "D2 23710 46U10 A18 F98 E58"
23710 is for an ECU
23 = electrical section710 = ECU ???-46U - Part Type number (A32 maxima?)10 - is distinction number (think revisions or different colors or change in materials, etc...)
The second number (A18 F98 E58) is the manufacturer's part #. The manufacturer in this case I believe is still JECS (Japan Engine Control Systems Co.).
By looking in Jim Wolf Technology's ECU Identification list, herehttp://jimwolftechnology.com/wolfpdf/ECU-ID.PDF you might be able to find an ECU that has the same features. As you can see, your part numbers are not there. There are SOOO many different ECU part numbers for a generation of nissans, and I suspect that they all are almost entirely just software differences (updates that adjust for better performance, fix bugs, raise fuel efficiency, etc..). Don't quote me, but probably any of the A32 ECU's would run your Maxima reasonably well but you will probably get a CEL if you mix and match OBDI and OBDII computers. Good luck!
