audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Mon Nov 09, 2009 8:44 pm
Above is the passenger side headlight. The yellow arrow points to the parking light and the red points to the turn signal. Reach behind the headlight to replace the bulb. As I stated before, on the drivers side you will have to move the battery out of the way to have easier access. Grab the gray plastic connector with your fingers and twist to remove.
