nissan maxima 2001 bad torque
nice_man_36
Car: maxima 2001 GV full automatic
hello every one
i have Nissan maxima 2001 full option VQ30 automatic gear im tird too much with this car i feel there is no torque its like 1.8 car and take too much fuel cuaz im always push more acceleration to let car run
i sent my car to maxima garage maybe he has any idea about this problem he try 2 days try change
1- MAF
2- clean throttle body
3 -change TPS
4- chk fuel pump and change 2 regulator
5- 6 coil and plugs
chk all pipe for air leak but its ok all
and car still need push half acceleration to run
i read there is maxima coming 220 hp and 230 hp if my car 220 hp it will be this big defrant ?
i read also this ECU need to program or can change hp chip is this correct ? to increase power ?
my friend have maxima 2000 he can make front tire racing but my car cant race it will normal move
OwnerCS
How many miles does you car have on it?
On my 4th generation Maximas and I30s, when the cars get over 100,000 miles, I change the O2 sensors with NTK/NGK OEM spec. So far it gives them more pep and better mileage.
nice_man_36
M feel engine sound defrant then other maxima car my car like bad respond take time to respond
I will take pic for my engine soon
nice_man_36
my car 242000 km
OwnerCS
That is 150371 miles. If you Maxima is still running the original O2 sensors at that mileage, they are over due for a change.
I have purchased 2 used Maximas at that mileage/KM and found the cars still had the original O2 sensors. After changing the O2 sensors the cars had better accelleration and produced better fuel mileage.
maxhopper
Car: 02 Maxima SE 6spd
OwnerCS wrote:That is 150371 miles. If you Maxima is still running the original O2 sensors at that mileage, they are over due for a change.
That car does not have O2 sensors. If you look at the picture of the engine bay there are no O2 connectors shown on the front of the engine.
nice_man_36 wrote:hello every one
Your engine is slightly different than the ones here in the US.
Are you saying you have to keep your foot on the gas pedal to keep the car running (like when you are stopped)?
nice_man_36
Thx for reply u are right my car dont have o2 sensor in front of engine i think back side there is too model some time will come front and i think this in rear side i will chk this
This same us engine only but body defrant its calll some times infinty or i30
the problem this car when stop in signal after move its not too much fast need push half acceleration to run
when car cold and start car its perfect after engine hot then be lazy again
nice_man_36
you are correct today i chk with nissan co. they told me ur car dont have o2 sensor
so why car lazy
nice_man_36
this video my car Nissan maxima 3.0 2001 gold color vs Nissan maxima 3.0 2000 whit color
i think now problem clear
[youtube]http://www.youtube.com/watch?v=syPuiRQh ... e=youtu.be[/youtube]
this road drive
[youtube]http://www.youtube.com/watch?v=96ONmrqk ... e=youtu.be[/youtube]
maxhopper
It could be the idle air control valve is bad. You can try removing it and cleaning it, and see if that helps.
Does your car have a catalytic converter in the exhaust system?
nice_man_36
maxhopper wrote:It could be the idle air control valve is bad. You can try removing it and cleaning it, and see if that helps.
this already i remove before and clean all throttle body with control valve its working ok
maxhopper wrote:Does your car have a catalytic converter in the exhaust system?
i dont know about this im was think maybe this need to clean maybe carbon close pipe but if u have any photo for this converter u can advice me
maxhopper
Here is a picture of the catalytic converter (I kind of doubt you have one).
Have you checked to see if the fuel injectors are working properly?
nice_man_36
u think maybe need to clean or change and if change all or only part
maxhopper
If you have a catalytic converter, it can become clogged. You can either replace it with a new one, remove the filtering material inside, or replace it with a piece of straight piping.
As for your fuel injectors, you can try running a cleaner through your fuel system. You can remove the injectors and have them tested, cleaned and have new o-rings installed.
nice_man_36
i check all somk pipe there is no any carbon inside and i dont have this catalytic converter
so what can i do for next step
Miguelone
Car: R33 Skyline 4 door
I'd start troubleshooting at checking for ECU fault codes, following this I'd also do a compression test to see if you have low compression in one or more cylinders that may be impeding performance. You say it begins feeling sluggish when it gets warm, it may also be coilpacks failing as they get warm. Checking the first 2 though will give the best base to work from.
mrahlsntd
nice_man_36 wrote:this video my car Nissan maxima 3.0 2001 gold color vs Nissan maxima 3.0 2000 whit color
this road drive
Dear,
I have the A33 series maxima GV, Year 2000.
Are you saying that you can't exceed the 80 Km/h limit ?
