Hey. I used to be on these forums alot but have not been on recently. I was wondering if I could get some help, as this place always had the best tech support forum ( I remember one user , "Nistech" , who seemed to know everything).
Any-who. Here is my situation
2000 Maxima shows code P1320. I've had this code several times in the past and have simply changed ignition calls and this remedied the problem. In all i replaced 5 coils. Still shows a code. I did the test where you start the engines and then unplug the coils one at a time in an effort to pinpoint which coil was bad. However each time I would unplug the coils, the care would stumble. Leading me to believe that all coils are fine.
I replaced the spark plugs. Still shows a code.
I replaced the crankshaft position sensor ( the one located by the oil pan). Still shows a code. I know that there is another crankshaft position sensor. But from reading the FSM it doesn't seem that the 2nd sensor is a probable cause of the code.
I'm running out of ideas and may just take it to a mechanic. Any ideas?
Thanks
Yashin
