satdog75 »
https://forums.nicoclub.com/satdog75-u98256.html
Mon Jan 05, 2009 6:51 pm
I had the same identical issue in the beginning of this thread. Ended up removing the ground to both bulbs, cleaning it quite a bit and reattaching it. Issue did not go away. Then my issue went to no high beams at all. Ended up being the high/low switch that is built into the lever on my column. Picked one up at a salvage yard, cleaned it thoroughly, applied new grease, installed it....and viola.....perfect every since. Traced back the old one and sure enough....it was the switch (wasnt making good contact so voltages were incorrect causing erradic issues). Should be able to find one for less than 25 bucks at salvage...clean it up, pop it in, and enjoy the "luxury" of working headlights...
