Nissan iPod interface, does it disable the iPod's UI?
bdu
Car: 2008 Nissan Versa SL HB
I've been considering picking up a Nissan iPod interface for my Versa, but a real deal-breaker for me is if it uses the iPod's "Advanced Mode" control protocol that turns off the iPod's own UI and buttons in exchange for greater remote control of it's feature-set.
Personally, all I really want/need is to be able to track up/down from my steering wheel buttons and a less clunky way to charge the iPod and get the audio into the head unit.
Anyone have experience with one of these to tell me what it does? Thanks...
coxcj
Car: 07 Nissan Versa SL HB Sapphire, conv pkg, audio pkg, sunroof, 5/07 mfg date, 6/2/07 purchase
bdu wrote:I've been considering picking up a Nissan iPod interface for my Versa, but a real deal-breaker for me is if it uses the iPod's "Advanced Mode" control protocol that turns off the iPod's own UI and buttons in exchange for greater remote control of it's feature-set.
The short answer is yes. With the iPod interface, the iPod's controls are disbled and all of the funtions are now controlled by the radio. It also does some other changes that are worth mentioning, most significantly is it automatically changes the playback to "repeat all". That annoys the crap out of me, but have a playlist setup that keeps this from being an issue.
Sorry for the bad news. If you find anything better, let us know because I'll be happy to change.
KimberKenobi
Car: the Camel
it takes the "shuffle" off? or it "repeats all" and also does "shuffle" if you have shuffle turned on...
coxcj
It takes the iPod off of shuffle and changes it to repeat all. You can change it after the iPod is plugged in, but you will have to make the change any time you power off the vehicle as well. Super P.I.T.A. when running errands and are in and out of the car all day.
My workaround is to have a playlist set up that I like, I'll have it set up on my computer in a random order, then choose the "copy to play order" for the playlist from iTunes. That would sufficiently randomize my choices so that I can just have it play straight through when I get in the car. Again, it's anything but a perfect system, but it's a lot better than paying for sattelite only to still have to listen to commercials.
Johniboi
Car: Versa
im planning on getting the interface also. But im trying to find a decent price for it..anybodygot any info on that?
coxcj
Johniboi wrote:im planning on getting the interface also. But im trying to find a decent price for it..anybodygot any info on that?
I got mine from the dealer. This was also back in July when there really wasn't any other option. I'm still not sure if there's anywhere that has anything different. Check Crutchfield or your local audio dealers. If you get the one from the dealership or the equivalent, it's very easy to install yourself. (check my "how to".)
FYI, mine was around $250. I don't remember the exact numbers.
bdu
That's a damn shame, but thanks for the info.
I may have to opt for a more hacked-up option, then.
KimberKenobi
Car: the Camel
*Holy Bump!*
But here's a question... has anyone with the stock adapter tried to use the "RPT RNDM" button that is on the stereo and does this shuffle/repeat/etc. the playlist??
kcourtad
Car: 2007 Nissan Versa SL Sedan
whoa wait wtf... i use my Ipod touch in my V all the time and i have to use the ipod to change the song nothing works on my HU but the volume... what kind of ipod do you have for doing that ?
KimberKenobi
Car: the Camel
It's not the iPod... it's the dock which works with the stock stereo... ~$200 from the dealership, plugs into the back of the unit... Not through the AUX jack or an FM modulator.
coxcj
KimberKenobi wrote:*Holy Bump!*
The buttons on the head unit don't function like they say with the ipod interface. It's really quite a FUBAR situation. The little booklet that came with the interface tells you what buttons are supposed to work for the menus and such, but I gave up quickly because they don't really match up to our head unit right, and it's really quite a pain when you're in the car and want to change things around.
KimberKenobi
Car: the Camel
*worty dird!*
JoshH
Car: Nissan Versa S 2007
Subaru BRZ 2013
For that price, you could buy a new headunit that works with an i-pod. Though, I don't know how that would work out with the steering wheel buttons.
KimberKenobi
Car: the Camel
JoshH wrote:For that price, you could buy a new headunit that works with an i-pod. Though, I don't know how that would work out with the steering wheel buttons.
for that price your steering wheel buttons would be useless.
coxcj
And for that price, you could have your stereo stolen within the week (like others around here have had happen). Any time I have ever changed out the head unit, the new one ALWAYS got stolen. After the third time I decided I would always keep the stock head unit and do what I could to make that one work for my purposes.
JoshH
Subaru BRZ 2013
For those with aftermarket headunits and steering wheel controls, you could try using one of these units: http://www.crutchfield.com/App...avf=N
Could probably find it somewhere else cheaper.
