Nissan Hardbody Registry
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Absolutely love that truck!
smurfmobile
Car: Nissan D21 King Cab 4x4 V6 lifted 36" 1991
Nissan D21 King Cab 4x4 V6 original 1991
This truck is.... I really do not have any words for it..... It's breathtaking, it looks so good, like it was dropped of from factory yesterday.
jonny 1988
Car: Nissan D21 King cab '87
Suzuki Sj 413 '86
Renault Clio '08
Like new!!!! :dblthumb:
goodoldd21
Car: 1987 Nissan SE-V6 Kingcab pickup, built in January 1986, purchased in June 1986, owned since new, almost 600,000 kilometers (Canada)as of Dec./13.
Thanks, guys! It is a good old truck. I've been taking some time to do the timing belt/tuneup. You know how it is…you start one thing and it leads to another and another! At the end of the summer the truck started running hotter than normal. I couldn't see anything out of the ordinary and the rad/ cooling system was flushed the summer before last. There were no leaks, so I thought maybe the waterpump was going as it has been in there since 2000, I think. Turns out that the radiator didn't have any fins left all around the shroud! So I now have a new rad, new waterpump, thermostat, hoses and belts ready to go in, probably over the weekend.
I also got around to scraping / washing off 20 years of oil spray out of the engine compartment (whew, what a job!) so it looks a lot better now. While I've got everything apart, I'm going to clean up the air cleaner base, the timing belt covers and assorted pieces and get them painted. It won't be perfect but it will look a lot better than surface rust. I figure that I can do sort of a rolling cleanup of the truck to keep it going strong and looking decent. It is really hard not to tear it down completely, like some of you folks do, and totally restore it. But I have other projects on the go that are ground up so I have to draw the line somewhere. Besides, I just like to drive my hardbody and I use it on a regular basis year round.
Hey Rev, how the repair of the deer damage coming on the green truck? Smurfmobile, any new stuff done on your trucks?
Regards, Gary
Rev_D21
Deer damaged was fixed. I have have jest been driving and enjoying the truck since then. Right now she's in the garage under a cover waiting for Spring to finally arrive. Working on my '91 red truck right now. Trying to finish up a slow moving transmission swap.
jaketho
Car: 86 Nissan D21
VIN: JN6ND16Y7GW010297
Year: 1986
Engine:z24i
Build Date: 6/86
Trim Level: XE
2wd/4wd: 4wd
Trans Code: FS5W71C
Axle Code:CA43?
Exterior Color: Grey
Interior Color: Grey/dirty
Exterior Factory Options: No idea
Interior Factory Options: Power steering, air conditioning
Original Selling Dealer: No clue, looking to do a carfax to shed light on this and other things
Mileage: 250,000+ (speedometer didn't work when I got it a few months ago)
Rusty but trusty!
Rev_D21
Awesome! Thanks for sharing your early D21.
jp2code
Car: 1994 Nissan D21 Hardbody Longbed V6
2001 Nissan Xterra SE 2WD A/T
2004 Nissan Sentra
deerhurst wrote:VIN:JN6HD11Y7GW001801
Year: 1986.5
Engine: VG30i
Build Date: 4/86
Trim Level: SE-V6
2wd/4wd: 4x4
Trans Code:Unknown, 5-speed manual
Axle Code:Unknown
Exterior Color: Silver/Red 2 tone
Interior Color: Red
Exterior Factory Options: Silver trim, fender flares ( never been installed )
Interior Factory Options: Manual windows, interlock switch, dual fuel guages
Original Selling Dealer: Royal Moore Nissan in Hillsboro OR
Mileage:120,500
The options part was cut out of the window sticker. Wish I had it.
Deerhurst: You posted a while back on Infamous that you have a HG41 axle.
Is that something you learned recently? Is that info not posted on your door jam?
Now that I've learned I can get the engine RPM down at cruise speed with an HG41 axle, I've been digging through door plate data trying to find out when these were put out there.
From what I can see, the HG series is the Limited Slip variety whereas the HF is the non-limited slip.
Rev_D21
1996-1997 Automatic 2wd trucks came with 4.11 gears. LSD in a 2wd is still pretty rare in all years.
Rauchnroll
Car: 1996 Nissan XE pickup
VIN:Image
Year:1996
Engine:KA24
Build Date:04/96
Trim Level: XE
2wd/4wd:2WD
Trans Code:5 SPEED MAN.
Axle Code:
Exterior Color:AZTEC RED
Interior Color:GREY
Exterior Factory Options: Full chrome package,14" alloy wheels (now upgraded to 16" Nissan alloy)
Interior Factory Options: (Tach, ps,a/c,intermit. wiper
Original Selling Dealer: If you know it.
Mileage:205,457
Rev_D21
Those Frontier wheels look good on a red truck. Usually I don't like them but on red they look excellent. Thanks for posting!
deerhurst
Car: 1986.5 D21 Hardbody 4x4 VG30i
jp2code wrote:[
Figured Id reply here too. I found the other placard in the engine bay a while ago and never updated in the registry. Info is not on the door jamb but in the engine bay. I feel that is a thing done on the early rigs. Havnt seen enough of them around here to confirm that or not.
I feel you are correct, the HG is LSD while the HF is open.
Rev_D21 wrote:1996-1997 Automatic 2wd trucks came with 4.11 gears. LSD in a 2wd is still pretty rare in all years.
Mine is 86.5 4wd 5 speed with 4.11. He can probably pull a v-6 4.11 ring gear off and fit it on his current HD rear diff.
Just ticked over 128K miles yesterday!
Rauchnroll
Rev_D21 wrote:Those Frontier wheels look good on a red truck. Usually I don't like them but on red they look excellent. Thanks for posting!
Thanks for the props on the wheels. I wanted the 16" cause easier to get tires and also a more aggressive look with a little more clearance. I also wanted to keep the factory look. So the X-terra wheels seemed to do the trick.
jonny 1988
Suzuki Sj 413 '86
Renault Clio '08
A lot of 86,5 !This is a good thing!
byubrett
Car: 1986.5 Nissan D21 4x4 SE V6 M/T
My first post here......
VIN: 1N6HD11Y6GC420269
Year: 1986
Engine: VG30I - V6
Build Date: 6/86
Trim Level: SE-V6,
2wd/4wd: 4WD
Trans Code: door sticker illegible
Axle Code: no placard under hood
Exterior Color: Gray
Interior Color: 215 medium pewter metallic
Exterior Factory Options: Graphics, Bumpers,Sunroof, bed mounted spare, LSD, Sliding rear window
Interior Factory Options: SE
Original Selling Dealer: Franklin Nissan
Mileage: 142,898
Rev_D21
That is such a beautiful truck! I love it! SEV6 regular cab 4x4, you don't see those very often at all. She's in great shape! Welcome to NICO!
[email protected]
Car: 2000 Maxima & 1993 Hardbody Kingcab
VIN: 1N6SD16S7PC415169
Year: 1993
Engine: KA24E
Build Date: (Found on Door Jamb Sticker)
Trim Level: (E, XE, SE, SE-V6, XE-V6, LE): Base
2wd/4wd: 2wd
Trans Code:
Axle Code:
Exterior Color: White
Interior Color: Red
Exterior Factory Options: (Spoilers, Graphics, Bumpers, Tire Size/Wheels, ect.)
Interior Factory Options: (Tachs, PW, PL, PS, ect.)
Mileage: 140,000
I plan to lower it 3", get new lower profile wheels & add a Cat-Back exhaust. I am in the process of replacing everything that normally goes bad in a 20 year old vehicle. I have already replaced: fuel pump & all rubber fuel hoses, brakes: including front calipers, master cylinder & stainless steel brake lines, alternator, water pump, radiator hoses, thermostat, stereo & speakers, front sway-bar & leaf spring bushings(Energy Suspension). I am dreading working on the front end bushings, steering & suspension.
Crazyreformer
Car: 1986.5 Nissan ND21
Here is one to add to the registry that I just bought in March 2014.
JN6ND11S2GW043341
1986.5
Eng.Z24I
6/86
Trim Base E
2wd
Trans. FS5W71C (5 spd)
Rear Axle HF37
Exterior color 468C Brown
Int. Brown
Options Sliding rear window,Front bumper, 195/75R14 tires
Int. options Base Pkg.
Location; Layton,Utah
Dealer; Tim Dahle Nissan,SLC,Utah
Mileage;64,155 original miles
I am currently repairing interior and other minor defects from being stored outside in a field for 28 years
Rev_D21
A JN6...very cool!
Thanks for adding to the database guys! Each one helps tell a story.
KyuubisBlade
Car: 2004 Infiniti G35 Sedan 6MT Sport,
1991 Nissan D21 4x4 King Cab
VIN: 1N6SD16Y5MC342819
Year: 1991
Engine: KA24 2.4L
Build Date: 01/91
Limited Edition
4x4
Trans Code: FS5W7 1C
Axle Code: CA41
Exterior Color: KH2 (Grey)
Exterior Factory Options: Chrome bumpers, mirrors, rock guards; Mud flaps; Bed liner; Sliding rear window; pop-out side windows
Interior Factory Options: A/C; Interlock Switch; Radio
Mileage:136,667 (at purchase)
Alright! Finally got a D21 of my own! Needs some TLC, paint work, but the interior is really good shape(except for a crack in the dash) and aside from the rear bumper there is no rust on the body or frame. Engine sounds great, transmission and transfer case shift smooth, the only thing mechanically wrong I can find is the U-joints on the rear drive shaft and the speedo cable doesn't quite work. Still gonna have my mechanic double check it for me. Just replaced both door latches so they can lock AND unlock. Need to replace the seals at the bottom of the crank windows, Then buff out the paint and repaint the roof of the cab. Overall I'm quite happy with it. Plan on adding a brush guard and some good lights, if I can't find a good mount on the stock bumper.
808ceez
Car: 1995 Nissan Hardbody
VIN: 1N6SD16S2SC381098
Year: 1995
Engine: KA24E
Trim Level: (E, XE, SE, SE-V6, XE-V6, LE) XE
2wd/4wd: 2WD
Trans Code:
Axle Code:
Exterior Color: Primer White
Interior Color: Blue (Stock)
Mileage: Over 180K
Rev_D21
Awesome thanks guys!
Midnight Tech
Car: 86.5 D21
84 Maxima
Found in U-Pull-it, Conway, SC. Fender flares drew my attention to it.
VIN: 1N6HD11S0GC393596
Year: 1986
Engine: VG30I
Build Date: (Found on Door Jamb Sticker) 4/86
Trim Level: (E, XE, SE, SE-V6, XE-V6, LE) SE-V6 (GST/SE)
2wd/4wd: 2wd
Trans Code: A/T
Axle Code: HG4?
Exterior Color: 424 (Blue)
Interior Color: B (Blue)
Exterior Factory Options: (Spoilers, Graphics, Bumpers, Tire Size/Wheels, ect.) Sunroof, Fender Flares, SE graphics, Chrome package, Pop-up Tie Downs
Interior Factory Options: (Tachs, PW, PL, PS, ect.) Tach, PW, PS, PM, bucket seats
Mileage: Did not look
jp2code
2004 Nissan Sentra
Aw! That one has got a sun roof.
I want a sun roof in mine.
Rev_D21
That is very interesting. Very rare too! I am curious, if you visit this truck again I would like to know some additional information.
If you have a micrometer can you measure the thickness of the torsion bars? Is it a one-piece or two-piece driveshaft? And does it have one or two piston calipers?
Hopefully you are able to visit that truck again sometime before it's crushed. Thanks so much for posting this!
Midnight Tech
Car: 86.5 D21
84 Maxima
I will do my darnedest to go back Monday for additional recon on this truck as well as it's 720 neighbor. No micrometer, but will find some way of measuring them, as well as verifying rear axle, driveshaft, caliper and mileage information. Would like to get interior trim because of the brushed aluminum accents.
Let me know if there's anything else you'd like for me to check on it.
Rev_D21
I'll post up here if there is anything else I can think of. Thanks again for posting up a cool truck. So sad to see it in the yard though, the body is cherry by NY standards.
ohtheguilt
Hi all, I've been a long-time lurker, but finally registered for an account yesterday...after 18 years without a D21, I finally bought another (brief story below)...
VIN: 1N6HD16YXSC306518
Year: 1995
Engine: VG30
Build Date: 09/94
Trim Level: SE-V6 King Cab
2wd/4wd: 4x4
Trans Code: RE4R01A
Axle Code: HG46
Exterior Color: KH3 Super Black
Interior Color: Gray
Exterior Factory Options: Chrome trim
Interior Factory Options: Just the standard SE Package, no additional options (no PW or PL)
Original Selling Dealer: Gandrud Nissan in Green Bay, WI; however, it was a dealer trade, so it originally shipped to Wilde Nissan in Waukesha, WI
Mileage: 118,792
I bought the truck yesterday (6/7/14) from the original owner, who was absolutlely meticulous about its care. He gave me a file that contained every (really, EVERY - even online purchases and parts shop purchases) receipt for the truck, and notes narrating what was performed and when. I am so pleased to have found this one, considering it was my dream truck when I was a high school senior in 1995 (and because my '88 4-cyl. 4x4 D21 was on it's last leg due to frame rot). So 19 years later (my '88 made it another year or so), I was finally able to pick up the cleanest one I could have possibly found!
Rev_D21
Welcome to NICO! Thanks for posting that up. Sounds like a nice truck.
Midnight Tech
Car: 86.5 D21
84 Maxima
Additional info on 1N6HD11S0GC393596:
Was told by one of the employees at the yard that this truck was an SE-I trim level. It has dual-piston calipers, a two-piece driveshaft, and what appears to be a 22mm front sway bar. Rear axle is an HG37, and it met its end at only 109,942 miles.
I was able to snap a few more pics of it today as well.
