I am new here and i think it's great being a part of this amazing forum.i need help with a nissan hardbody 20002 model,v6 engine,it has an ecu part number MECM-W895 A1 2904.
now the problem is that when i switch the ignition on the engine light flashes and then stops and remains on,when i try cranking the light start flashing and will only stop when i stop cranking the engine.I tried a diagnosis using my ELM327 bluetooth but i cant seem to get a communication with the ecu.i tried using my SSB key programmer and still cant get to the ecu brain.
Can some one help with the ecu pin outs so i can check if i am missing a voltage input or something like that,or is there a trick to get the car started?
I have checked the key using my AD90 and the transponder seems to read ok.
Any ideas?
Thanks in advance.
