Nissan GTR Brake Fluid in a 300zx??
rewjr69
Car: 1990 300zx 2+2
Upgrading my brake lines to Goodridge Stainless Steel lines.
Can I use Nissan GT-R R35 Special DOT-4 Brake Fluid in my 90 300zx NA?
There's nothing "special" about the fluid in a GTR's brake system.
If you switch from DOT3 to DOT4, make sure to flush the system thoroughly. It's a bit of a waste of fluid unless you're doing some serious track time (and need to increase the boiling point).
Just use a good quality fluid (I like ATE Super Blue).
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Only difference between the two is slightly higher boiling point. Make sure you stay away from DOT 5 though, it is very incompatible with the others.
