centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Thu Dec 21, 2017 12:53 pm
Well, the OBD-2 scanners are fine for pulling code numbers and ready system check monitors. The consult 3 tools cost quite a bit more and can be used for deeper diagnoses per instruction from the FSM. I use the FSM, a voltmeter, and my OBD-2 scanner and have not yet needed a consult tool. Most FSM procedures are outlined with instruction for using a consult tool first and then again for using just your basic voltmeter so I just use the second set of instructions. I'd check reviews of the products available. You'd be looking for a Nissan Consult 3 tool. You could search the threads here as well in case one of our users has made a review.
Did you find your FSM here?
Welcome to NICO Club!
