A/C Question - Nissan Frontier 2005/4.0
gaby01
Car: 2005 Nissan Frontier/4.0 Nissmo model
I have a problem where i can not get my a/c compresor to turn on? i checked the fuse and also replaced the a/c condensor that was damaged but still can not get the compressor to turn on? any help would be very much appreciated? thank you all.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Hi Gaby, Welcome! I'm moving this to the trucks forum!
Q451990
Welcome to NICO!
Have you recharged the system with refrigerant (134a)?
A quick rundown of the conditions that have to be met before the ECU will send the "on" signal to the compressor.
- Dash switch set to on or defroster selected
- Dual pressure switch (on liquid tank/dryer) must not read too low or too high
- Temperature sensor on evaporator coil must not read too low (no freeze up condition)
- Temperature overheat sensor on compressor must not be open (result of compressor overheating)
You can read more about your a/c system in the factory service manual (FSM) at www.nicoclub.com/FSM/
When I replaced the evaporator on my Hardbody, I had trouble getting new refrigerant to flow into the system to get the pressure above the floor required by the dual pressure switch. I had to remove the compressor relay and short it out to get it to come on and pull in the refrigerant.
Heath
gaby01
thank you for the feedback and i will give it a shot and see it if solves the issue.
