Nissan Frontier 01 Front brake rotors stuck
rainekbaker
Car: 01 Frontier
Pads where a quick job but for the life of me i could not get off the rotors to replace them. Do you have to take off the automatic hub assembly in order to free the rotors? I removed the 6 bults that were going into the rotor it self but i was still unable to free it up. The hub started to seperate from the rotor but then they both got stuck, and now the rotor will not spin freely. anyone have this problem before?
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
On a 4wd you have to tear it down all the way to the spindle. Remove the hubs, snap wring, retainer washer, and hub nuts. It's a good opportunity to repack wheel bearings and replace grease seals when you get it apart. It does require some "feel" to know how tight to retighten the hub nut.
