Hello, First off id like to thank you all for this wonderful forum. Ive been searching for a good nissan group that will help me with my car troubles. Finally here it is!
I have a 91 Nissan Stanza that has practically the same engine as a 240sx (KA24DE). I bought it 3 years ago and it has 120k on it. Its been a great car up until about a year ago when the transmission failed. I had that repaired drove it for about 4 months trouble free. I bought a 4x4 truck for work and decided to park the Nissan for While for the winter season. I would occasionaly go outside and start it to make sure everything was ok. The gas tank had about a half tank it and I added some Stabil gas treatment to it to keep the gas in working order.. Everything was fine. When spring time rolled in I decided to put it back on the road and thats when I discovered an Engine problem.
The engine would start fine. And Idle roughly. I tried to rev up the RPM's but as soon as I gave it gas it would want to choke right out. I Imediatly let off the gas and it went right back to idle. I experimented for a bit and noticed that if I baby the gas very lightly add pressure to the gas pedal it would eventually rev up. I tried to put it into gear (Automatic Trannsmission) and it died right away. Basically the engine apparently cannot handle any load.
I started troubleshooting.. I checked the simple things first. All the fuses were fine. Air filter was acceptable. Took a close look at all wires/connectors everything seemed to be fine, no corrosion seemed to be present. I then went to the local parts store and bought a fuel filter, air filter, PCV valve, spark plugs, O2 sensor, wires, Dist cap/rotar. After installing all those i became confident and started her up. Problem was still there. I then started asking local garages about it and they seemed puzzled like I was. Many suggested to check the fuel pump, MAF, and Cat/converter. I tried the key in the "On" position and noticed the fuel pump primed fine. Since the garage had told me to test it that way and if it works in a prime cycle then it would be fine under normal operation I figured it was fine and didnt want to go further with it if that wasent the problem. I then got desperate and had a hunch that the cat converter was plugged so i removed it. I could see light on the other end of it.. it seemed to be firm with no loose parts inside. I reinstalled it. I removed my MAF and brought it to a Nissan dealer and they tested it (Free of charge) and said it was fine.
Since after all this and it doesnt act right I gave up on it and parked it. This all still bugs me very much and ive been reasearching on the internet quite alot latley and came across this web page. I found the FAQ topic
http://www.240sx.org/faq/articles/carstalling.htm
very helpful and it gave me some insight as to what may be the problem. Although I did try gas cap trick, and that didnt work. This page mentioned something about a "Coldstart valve" I would appreciate if someone could elaberate on this some please and give me a hand. =]
Thanks, Malibu
