s13sr20chris wrote:hold up now. for a short time s designated carb. in late 80s when most everything was fuel injected.
S designates carb only when there is a fuel injected version of the same engine.
For instance, the L24, used in the 240Z has no letter for fuel delivery type. However, the E16S, used in the Sentra, uses the "S" designation because of the optional E16I, which was throttle body fuel injected.
Also, to confuse even more, a designation of "B" is two differentiate between 2 configurations of the same block design. An example of this is the L20, an I-6 used in the Skyline, and the L20B, an I-4 used in the 510. Both are "L" series blocks, but one with 4 cylinders and one with 6.
If somebody can host this *.xls file for me, I have compiled an excellent list of engine codes to learn from.
