nissan emblem
All things Altima Coupe.
icedelman
Car: 08 nissan altima coupe
Does anyone out there know if the trunk lid emblem is glued on like the letters or is it drilled on
mikegtr06
Car: 1995 180sx
jsut glue
tomce'
Car: 2010 Altima Coupe 2.5S, ALERT RED
Glued. Loose it
icedelman
any suggestions on how to remove it?
losenone
Car: AC 3.5 CVT K12
Beak
Car: 08 Coupe VQ
use dental floss to wedge in the glue and pull with all your strength!!! heatgun if needed .. once you have it off use goo be gone or wd40 to remove the adhesive. dont worry if it does not all come off a wash and wax will take care of it. good luck
Beak
Car: 08 Coupe VQ
fishing line if you have it it stronger than floss
ESP
Car: 2008 SexyBlack A/C
BE CAREFUL WITH GOO GONE & WD40!!! That stuff'll strip your topcoat if you rub too hard. It's best to just heat it up with a hairdryer, NOT a heatgun. Heatguns get way too hot if you don't know what you're doing with it and will damage your paint before you know it.
Dental floss to lift up the edges, strong fingers, and a hairdryer are all you'll need. Wash and wax the spot afterward and you'll be golden!
icedelman
I want to thank everyone who gave me great info...finally got the emblem removed. Took alot of work but it looks really clean. Will post pics soon.
