sdkhalsa »
https://forums.nicoclub.com/sdkhalsa-u28278.html
Fri Nov 03, 2006 6:59 am
Have a question about Nissan DataScan. There is a temperature dial on the monitoring panel. Is this gauge temp. or ECU temp? I suspect a faulty ECU temp. sensor, as the idle which previously ran a very solid 750 rpm under all loads and temperature is now over 1000 when fully warmed. IAC seems to be fully functional with a duty cycle of 8% at idle with no accessories. Have checked carefully for vacuum leaks, incl. EGR, and have not found any. Still looking for Nissan DataScan Manual, if anyone knows of any.
