eddiec wrote:devious: how does your pda interface with the consult port?
and are you saying that you are currently developing an app;ication to run on a pda to interpret the signals from the ecu (through the consult port)?
i'm more interested in how the pda receives the signals from the port.
The pda interfaces in the same way other rs232 devices (laptops) interface with consult. The circuit required is simply a low level (ttl, 5v) to high level (rs232, 12v) signal converter along with a clock signal generator to initialize serial communication with ecu. It works with plms, blazt, and zcontrol circuits (as well as others). The wires of interest that come out of the consult plug are TX, RX, and CLK.
Thats the easy part, the communication protocol (command-recieve format) is the tricky part to get setup properly. The app of mine is written in easy to use basic. Id be willing to share any information.
If anyone reading this is skilled in the art of 8 bit motorola microcontroller code writing, I need your help for something grand! I am working on a fully self contained real time tunable ecu, using a modified oem ecu that is running RAM instead of ROM. It will eventually be similar to power fc or reytec type ecu, i have it 85% finished. I have done a lot of work on it so far, but would really like some group effort if at all possible. Regardless ill continue chugging along on the project. It uses ka24e mainboard, heres a picture of the prototype.
ps, date on pic is not correct.
