photographybytmc wrote:Just finsifhed 8 injectors, 2 knock sensors & 2 O2 sensors, Fuel Pump & FPCM..argh!..after all this ... got Code: 45 injector leak. Went away.
It's been a couple of years so my memory is fuzzy but I believe ECU code 45 on a California Q means your O2 sensors are toast and not that your injectors are leaking. Was it a stored code or had you cleared the codes after the O2 sensor install? If it doesn't come back I would say all's well.
On NDS the needle on the O2 sensor gauge should be swinging pretty fast between 10%-90%. I'm not sure on the rest of the data you're asking about.
