Nissan consult errrrrrrrrr why wont it work......
preston240sx
Car: Nissan 240SX S13
ok so i have a rb20 and i decided to try my consult out... so i went on ebay and bought a 30 dollar one and after waiting a month to get it i notice i needed a serial to usb cord so i went to fryes today and picked one up for 14 bucks after i got home i hooked everything up and used the consult software and everytime i tried to connect i kept getting the same window..... unable to open com port (win error code 2) i changed the port on my computer to the port i was using on the consult still get the samething ........ i cant get the ecu to read anything but my car runs just fine i dont understand whats going on i've read it can be the serail adapter but how much can that influence if anyone can show mw some insight please hit me back
Modified by preston240sx at 11:36 PM 1/1/2010
sil8tdrftr
Car: 240SX coupe, fastback, vert
the consult tool is mainly used on obdII and mostly usdm... unless there is a JDM consult version that has RB series info in it which is the one i hope you sourced cuz thats probobly the one that would work for it ... idk much about that stuff but from my knowlege thats what i understand
preston240sx
nahh the obd1 came with a nissan consult connection same with my rb20 same one
sil8tdrftr
well at my school i tried hooking up a consult to my s13 SR swap and i got nothing... but i think its because its a swap... meaning i had modified the harness to be used on the usdm connector from the ECU and what not... im sure if you did the same that youre probobly not gonna get simple perrameter readings and codes at all,... but i wish you the best of luck none the less
audtatious
Maybe the serial cable you are using is incorrect. See what pinout the Consult needs for the cable as you may have an issue with pins 2 and 3 being crossed improperly.
SirSilvia
Car: Sold both my babies
what year is the ECU? I had a similar issue, and turned out it was because my ECU was too cold. I have an '89 KA24E though
preston240sx
well there's awrite up on where ur consult go's and how to wire it on nico im pretty good a wiring so i know i got all the right wiring going where they need to .....how would i know if i have the right serial adapter i thought they are all the same should'nt they be ??? anyone have a clue which onw would work and where can i get it also i was get a parameter message that popped up too but i had no idea what that ment my bad .... not sure what year rb20 its ... its a rb20 harness i had done at neotech in santee cali... nick did it and left the consult wires so i could add a plug later so i added the plug and here's where i stand with an adapter im guess that wont connect....
vancouverbc
Car: 1991 240sx
zer...nsult
This tutorial explains it. Its hard to find a serial adapter that works. I finally just bought bought the other kind of cable at ecutalk. the serial adapters that work are almost as expensive as the cable it self.
