WesQ »
https://forums.nicoclub.com/wesq-u84390.html
Sun Jun 27, 2010 9:41 pm
Is any else finding it difficult to find a Nissan/Infiniti shop that has a Consult test station? After the RH seat control stopped working on my 94 Q, I used the FSM to check bus connectors and to test power to the control unit, seat switch and motors. It appears to be a failed control unit or seat switch, but I could not determine which. So, I decided to take my Q to a shop to have it tested using a Consult. All Import (aka Jerry Tucker) said they don't have one anymore. So I went to an Infiniti dealer who said they had a Consult and would isolate the failed unit and perform a complete diagnostic check on the Q. Later Friday, when I checked my voice messages, I had a message from the Infiniti service rep who said their Consult did not work on my Q's LAN architecture. He said my 1994 Q has a old style architecture which their modern Consults cannot test. Is this right? Can the current Consults test the older 94 LANs?
Then it got better. The service rep said thier technition isolated the problem to a burnt out seat switch which costs $1250 to replace. But if this does not fix it, there may be more problems involving the BCM or seat control unit. Ouch!
