nissan consult 3 plus
mokymok
Car: fx 2009
Im new to forum and need help so here goes, I bought a copy from china of c3 plus, it works great except one part
It wont allow me to unlock/release steering wheel in push to start infiniti when no working key present... In nissan, you can put ignition on without working key, just put blank fob in port slot and voila... When I try to read bcm and get 4 digit pin to go in programming mode and unlock steering, i go in immobilizer menu, select car year and make, hazard lights are on, error code comes ecu cannot be detected make sure ignition is on... If I do same procedure with ignition on, works like a charm, keys are copied into ecu
If ignition is ON, steering wheel is unlocked, thats all ignition on means in push to start, that steering is unlocked... Machine is basicly telling me, you need steering wheel unlocked so I can unlock it... Other tools can clearly unlock steering when ignition is off, so is it my tool might be defectious, my technique is bad or just plain old unlucky and thats only feature the clone c3 plus cannot do from original ?
Any help/discussion on this matter would be appreciated, im currently contacting seller/manufacturer, ill keep you posted if I get any results
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
sounds like a easy way to steal cars...
mokymok
Car: fx 2009
I am not sure about that... I first encountered this when a client had lost all keys, and had to send him to get towed at dealer cause I was clueless
Im verifying if its my technique, or I should feel ripped off by seller due to machine not functioning well ? Any after market machine made for nissan can unlock steering wheel of nissans, so im still wondering why
In 5-6 hours, I should know more from manufacturer im guessing
