Thankyou you for your reply it's appreciatedVStar650CL wrote: ↑Tue Apr 16, 2024 1:57 pmTo my knowledge that type of 3-wire COP is wired identically on every Nissan, pin 1 is trigger signal from the ECM, 2 is ground, 3 is 12V ignition power. If any of them are already wired correctly, you can tell the right order from the colors. Power will be the same color wire on all 4 coils, and so will ground. Only the trigger signal will have a different color on each coil.
