Cyclemut »
https://forums.nicoclub.com/cyclemut-u60862.html
Wed Apr 11, 2007 8:23 am
Does the car shake at all? Like a really fast vibration when you rev the engine?
You might have thrown a damper spring, and a part is resting against the bell housing, causing the noise. This would also explain why the pedal is coming up slow, as a part of the spring may be getting pinched between the disc and pressure plate, squeezing out slowly.
If this is the case, then it's a very short time before something catasrophic happens. It could lead to a transmission replacement if not repaired soon. I'd have it professionally checked out, and they're going to want to pull the transmission to investigate the clutch.
