SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Mon Mar 09, 2009 3:27 pm
Bump for the exact same problem.
I cannot find the pinout for the xia-i01 box, I finally stumbled on this thread. NICO FTW yet again.
When I started this "project" had the unit powering on to charge my iPod but no sound. The manual for the harness for my 95 uses an illegible foldout style diagram, and they radios are interchangable and their output has to be controllable through that 12 pin connector. The limitations for models is something I find a little strange since the 97j has the same radio as the 99Q although this component is available for the Q.
Through frustration I may have separated the 12 pin connector entirely, they are pretty flimsy. Now I am sort of lost I managed to find the pinout from the 98 Q45 that has the same radio and as the OP said a while back, I wanted to use the unused CD CHG button to activate the AUX function that this radio has.
The wires on the female end of the harness look pretty straight forward pinout wise. The colors almost fully match a normal wire color code, there are a few extra ones that I cannot find though.
I've been staring at this for a few hours and tried several variations based on pinouts from the esms. I did not try crossing the tx line and the power.
If this makes no sense I apologize this simple addon to my radio has consumed the better part of my day and now I need another beer.
This is why I stay away from the aftermarket.
Oh and does anyone know where I can get a microphone for a Parrot Mx6000 BT unit? Some D bag cut the wires the unit that I have and I cannot fix the coaxial cable enough to get a strong enough signal.
/rant ugh it's been a long day.
