CassJDMGirl »
https://forums.nicoclub.com/cassjdmgirl-u231920.html
Wed Feb 19, 2014 6:36 am
Hi all,
My name is Cassie, I recently bought a Nissan Bluebird 1995 SSS (AKA: Altima) and it has 218,000 KM - KA24DE Motor
It was running real nice when I bought it (3 weeks ago) - and haven't really driven it since. I went to start it up and now the engine light has come on
The car was also had an unusual idle.
I went to check the engine, and noticed both radiator, and thermo fan were on. So I thought that was quite unusual as the car needs to get warm and not cool down on start up...
I took it for a test drive for around 3 minutes around the block (car was still at normal running temperature). I stepped on the pedal and literally did not perform it's best. It felt sluggish on accerlation, with slight "hiccups" along the way, as if it were over fuelling. Also the fuel meter was dropping down quite quickly for a short drive ! I then went to stop in home, hopped out and both fans were still on..
I also noticed the revs were very irregular, dropping then upping back to revs consistently. I also noticed the sound coming from the exhaust, quite loud and inconsistent sound. It smelt quite bad, similar to fuel and coolant... Also had mild white smoke coming out.
I know the whole distributor looks like it may need replacing (leaking oil).. but surely would not cause the white smoke or both the radiator and thermo fan to be on..
I pray to whomever it is up there that this isn't a head gasket but it sure seems it..
Could anyone give me any direction or may know exactly the problem?
Thank you.
