nissan badge removal
jinhsuh
Car: '08 Altima Coupe 2.5S
how do you take the nissan badge off in the back? i was able to take off the 2.5 and the altima badges with a blow dryer but i can't seem to get the nissan one off. do i need a heat gun or something?
bundy26
Car: 2011 Buick Regal turbo
I took my badges off with a blade, put flat against the paint but not touching, then put it on the tape that holds the badge and just lift it with your fingers, piece of cake.
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
you are nuts to bring a blade to the paint...Grab a reel dental floss and floss that **** off... thats the easy way
MisfitBrian
Car: 2008 Azure Blue Altima Coupe 2.5S
LongBeachCoupe wrote:you are nuts to bring a blade to the paint...Grab a reel dental floss and floss that **** off... thats the easy way
Agreed! As for the original post...I didn't take the Nissan badge off, thought it looks good. Could it be attached to the trunk with screws?
LongBeachCoupe
2005 Lexus RX
ALL of the emblems are double sided taped...
Take some of that oral-b to the nissan emblem.. you will see..
jinhsuh
i mean i used floss and got the altima and 2.5s off but the big nissan sign is tricky... no matter how long i heat it for it won't come off! and hell no i'm not using a blade on my car.
prlwhitecoupe
Car: 2008 Pearl White Altima Coupe 2.5 S w/CVT & Premium Pkg.
yes its tape AND probably screwed, there are prolly two holes for prongs if no screws atleast.
I know cause my old accord symbol had to be replaced on the trunk....
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Actually, I'd be surprised if it used any sort of physical fastener (clips, screws, etc.). I haven't seen a Nissan that did for years, even on the Nissan emblem (unless it's in/on the grille).
If floss isn't cutting it, try a steel E-string from a guitar.
LongBeachCoupe
2005 Lexus RX
A STEEL STRING? Isnt that essentially asking for a screwed up rear end??
Jin, its not screwed on... and ive seen a friend take it off using only floss... you need to think of those lumberjack guys on tv cutting thru a log... its the buffing/sawing action going back and forth thats going to have the floss rip thru the 3m tape... use the "silk" style floss that looks plasticlike... and you will break like 5 strands while getting it done, but it will work... all you need to do is be able to get a portion of it up, then rip the rest off.. i know it sounds nuts, but it wont leave a mark... id do this before i touch a STEEL ANYTHING to my paint.
Altimus_Maximus
Car: Altima Coupe 3.5 SE Superblack
I got the nissan badge off after switching from floss to twine.
The twine had a rougher texture that helped to "saw" through the tape. Once you get it worked through the top "bun" of the burger, you can grab it with your finger and pry it the rest of the way off. Then you can easily peel off the tape that remains on the car.
It can be done. But it is frustrating. Good luck!
rfx45
If everything else fails, buy one of those 3M adhesive removal spray. It's like a tar and bug spray but slightly stronger. Heat up the badge and spray some of those on. Let it seat for a 30 seconds to a minute and then spray again and start pulling or using the floss again. The spray should soften the adhesive enough to be taken off easily.
Hope that helps.
jinhsuh
haha i should try some new floss... everytime i try the sawing motion with the kind of floss i'm using, i cut my fingers and not the tape lol thanks for the advice guys, i'll try it next time.
bembol
Car: 2015 Nissan Murano SL AWD Cashmere Interior
To confirm the NISSAN is taped too right? I want all of them removed!
I'm going to ask my dealer to do it, so I don't have to bother with the Goo.
jinhsuh
after intense blow drying and many snapped floss, i have finally got the burger off. some tough tape. if you're trying to take off the nissan badge, get a friend to help you. use floss the cut the tape while your friend blow dries it. so much easier. and fyi no badge in the back side is screwed on. it's all just super hard tape. don't waste money by going to a dealer. just use wipe away or goo gone that you can buy at your local wal-mart and it'll get the sticky stuff off
jmicha3l
Car: 07 Nissan Altima 2.5S black
rfx45 wrote:If everything else fails, buy one of those 3M adhesive removal spray. It's like a tar and bug spray but slightly stronger. Heat up the badge and spray some of those on. Let it seat for a 30 seconds to a minute and then spray again and start pulling or using the floss again. The spray should soften the adhesive enough to be taken off easily.
Hope that helps.
Or you can use Goo Gone. After you remove the badges. Wax it.
