NISSAN Altima parking lights, dash lights dont work
General discussion area for the L30-chassis Altima
nate5607
Car: NISSAN Altima
i bought new parking/cornering bulbs for my 2001 NISSAN Altima, i installed them, then i turned my lights on, they worked fine, then i used my turn signal, which makes my cornering light get brighter, when i did that, my lights turned off and wont work now, parking lights, cornering lights, and dash lights all dont work. is this a blown fuse? if so where is my fuse for this, and if not what else could be wrong? i would appreciate help since i cannot see my dash at night and have no idea how fast i am going...THANK YOU
Alfador
Car: 1990 Nissan 240SX Hatch
You'll have better luck in the Altima forum or perhaps the N.O.M. forum is the problem is extremely perplexing and technical.
altimecca
Car: 04 Nissan Altima S 2.5
that's beat. there's two places where the fuses can be found. one is in the engine bay, and the other is found under the dash, driver's side. did you make sure that the wattage on the new bulbs where the same as the ones that came with the car?
Return to “2nd Generation Altima Sedan (1998-2001)”
