lexcrob »
https://forums.nicoclub.com/lexcrob-u106680.html
Fri Apr 14, 2017 11:45 pm
Normally shaking on accel. in a fwd car is worn engine mounts. It could also be a cv axle joint but the only way to know for sure is to remove them and give them a articulation by hand and see if they bind. Of course the joint will hopefully fail and blow the boot that way you dont have to take them out to check them...
Id check all the mounts if they or one is worn upgrade it to a stiffer one if its available.
