nando989 »
https://forums.nicoclub.com/nando989-u278584.html
Sat Feb 10, 2018 8:45 pm
I’ve been having this issue for a while now. Noticed that it happend after I changed my alternator. The vss was changed and works fine intermediately. If your foot is on the excellerator it jumps up and down until you let go of the pedal. If you floor it it works normally as well. So it only works full throttle and when the gas pedal is released. Also when the speedometer is jumping around you can feel the engines rpm fluctuate with the speedometer jump. Not so much the rpm gauge. I have a new vss from 1 a Auto and I put the old one back in. Same results. I also have code p1574. I changed the sensor that has the gear attached that is driven off of the transmission diff gear. any idea what to check?
