Nissan 7 bolt T3 Flange from Z31
Chezedik
Car: 1991 Nissan 240sx
Does anyone know where I can find one. A local machine shop ballparked it at about 50 bux to make one, I don't really want to pay that. (Almost) Any suggestions are welcome. Also, if no one has any good ideas, but needs one, maybe we can all save some money and make a few.
1995240sxSE
Car: 1991 jeep wrangelr and a 2004 ford taurus
i can trace mine and cut one outta steel for you if u wanna pay for steel and shipping? It shouldnt take me too long! Email me at [email protected]
Chezedik
Email sent, I hope we can work something out.
kaizenveryfast
Car: 1993 240SX Sold April 08 after 10 years of daily
Hey, if you are talking about Payne's they do good work. I know they are expensive and probably take longer than they should but I have had good luck w/them and the flanges they have made me were good quality
Chezedik
Yes, it is Payne's. I am not questioning their work, I am just looking to save a few bucks, but it's not looking good. So I going to see if anyone else needs one of these, so we can maybe all save some money. Kind of a group buy.
hnugen
blaast performance http://www.blaastperformance.comI usually dont point anyone to them because the guy there (guillame) is a lying sack of sh-t but they seem to be the very few shop selling them.
Titan
Chezedik wrote:Yes, it is Payne's. I am not questioning their work, I am just looking to save a few bucks, but it's not looking good. So I going to see if anyone else needs one of these, so we can maybe all save some money. Kind of a group buy.
Are you joking?
$50 isn't all that bad for a machine shop making a one off flange. Infact, that is a bargain.
Dimensioning and milling the port out alone is alot of work.
I know when I made mine, the time I put in on the milling machine was well worth $50.
Spend the money. This is an area you do not want to cheap out on.
Chezedik
It is a flange, mechanically it is unimportant. The extent of it's job is to be flat and have bolts run through it. If the metal is of reasonable quality we are talking about a good with infinite substitutes. So yes, this is an area where I can afford to go cheap.
Chezedik
Oh, and in case you didn't catch the drift of this post, the idea was to find one that was already manufactured. I know that a one off would be expensive, but if I could find someone who already made it I would save money. This has been accomplished, thank you hnugen. He may be a sack of ****, but it is an option.
Titan
Chezedik wrote:It is a flange, mechanically it is unimportant. The extent of it's job is to be flat and have bolts run through it. If the metal is of reasonable quality we are talking about a good with infinite substitutes. So yes, this is an area where I can afford to go cheap.
Simply because it does not have moving parts, does not classify it as unimportant.
In case you have not noticed, the port profile is no simple shape. It is more of a kidney. Not to mention you must have proper clearance for the wastegate flapper, if you intend to use the internal wastegate.
Furthermore, all this must be as closely milled to the original as possible. As there is little clearance for nuts/washers or bolts when you weld pipe to the flange.
Trust me, this piece is important.
Listen, bottom line, I'm not trying to come off as a prick.
I run a Z31 T3, and having fabricated and machined everything myself, I know what is critical, and what is not. I know what to look out for.
Many people have struggled with this flange, and you would benefit from heeding other's experience.
