There should be any issues using any OEM Nissan wheels so long as they fit and you use the correct sized tires.
Where you start to have problems is if you use incorrect offsets. This can negatively affect suspension and wheel bearing life.
For a brief primer on tire and wheel sizing:
Plus sizing:
http://www.tirerack.com/tires/tiretech/ ... ?techid=25
Wheel offsets:
http://www.tirerack.com/wheels/tech/tec ... techid=101
Tire size chart for the Rogue:
aftermarket-wheel-tire-fitment-chart-t293478.html
Some Rules of Thumb:
- Keep the tire diameter with 3% of the OEM tires.
- Keep the wheel offset within +/- 3mm of stock (Stock offset is 40mm)
If you want to know more about how wheel offsets can affect handling, do a google search on 'wheel offset scrub radius'.
