Nissan 300zx z32 ignition fuse keeps blowing
Aaron8798
Car: 1990 Nissan 300zx z32 n/a manual 2+2
My main ignition fuse under the bonnet keeps blowing and was wondering the best things to check
macgiver
If you can get to the starter, under frame ,locate ignition wire that "energizes" the solenoid and remove it.
This better be done AFTER Neg batt term disconnected for safety , safe-off by taping loose wire , re-connect battery and turn key to start . You have eliminated solenoid Short ckt. Continue by removing successive relays upstream as you go , Schematic a must.
TIP - buy those Ckt-Braker fuses that reset ,if size available, $4 ea ? Saves Blowing all those "test fuses" :rotflmao
Use your ears to listen for any sparking , your nose - sniff out smoke/hot wires as precaution as you go,anytime connecting a "jumper" from B+( Battery Voltage) - have a FUSE IN SERIES to your test destination.Lastly , never use larger fuses into the fusebox - you WILL smell smoke/see fire ! :lolling:
