Nissan 300zx tt spoiler
Lukasz86nyc
Car: 1990 nissan 300zx twin turbo
Hi guys. I brought a twin z design spoiler for nissan 300zx tt
And. I try to put 3m tape but dosent work any body try install
This fiber glass spoiler. On top of hatch any glue.??? Recomedation. Thanks
DCaff300ZX
Car: .
1993 CRP TT- Modified
Removing the old spoiler (if necessary) and installing a new one on these cars (Z32) is a real challenge, and should probably only be done by professionals for best results.
The removal of an existing OEM wing is a big difficult problem to solve, and damage to the hatch is nearly impossible to avoid so there's that to figure into your job. Specialty adhesives and some fitting are necessary for the install of new wing, with the ends held down by bolts from inside and the rest with the correct adhesive and fit. There are a few youtube videos of this work if you search hard enough, and I did see a writeup somewhere but can't remember where...searching can be your friend if you try hard enough.
Anyway, if DIY/search results aren't able to help I'd start with contacting a competent body shop who has done that specific work before preferably, and see about them doing the work unless you have skills in this area.
Good Luck!
DCaff300ZX
Car: .
Just out of curiosity today and assuming I'd find what I did, I simply googled "TwinZ spoiler install" and was directed to the CZP site and TwinZ spoiler page where there clearly is a link to installation of the wing. Same with Z1.
I'd suggest following that link to 3ZC and that post, and there you go...again, search is your friend.
