NolimitZ32 »
https://forums.nicoclub.com/nolimitz32-u100070.html
Fri Oct 16, 2015 6:02 am
1. the fan is a manual clutch fan, it is connected to your engine and spins when the engine is on, it doesn't have a separate electric motor powering it, it is always spinning. To check your clutch fan is pretty easy, search the site for "testing fan clutch" and you should come up with quite a few how tos.
2. AEM, Defi, Prosport,Autometer, etc. depends on your budget. I would go for a high end electronic unit such as Defi or at least Prosport.
3. The fuel pump is not integral to the sending unit, the pump and sender share a cradle but the pump itself is separate, sold separately, and operates separately from the sender, go through the troubleshooting before throwing money at stuff.
