Nissan 300zx Power seat broken ?
mrcraka
Car: 93 Nissan 300zx TT
Hi I searched for a thread relatign this issue but I could not find one. On my 300zx drivers side the seat is broken. The power swtich only works for up and tilt, but it will not move the seat left and right. How can I mannualy move the seat closer to the wheel, and how much would it cost to fix the seat ?? Could someone provide me with a sep by step picture guide on how to move the seat. Thank you
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
to remove the seat simply unbolt the 4 corners fo the seat the trick is trying to get to all 4 without moving the seat, you might want to try openign the swithc panel and try cleaning the contacks to switching out the control switches, there is no manual way to adjust the seat
xclusivez32
Car: 1990 300zx 2 seater limo
tt engine build
2004 gmc serria
if the switch is broken i would suggest buying a new one hooking it up to the plugs. that way you can move the seat to unbolt it and then install the switch to the seat and reinstall. it is not a hard task i just installed an electric seat in my car that didnt come with an electric seat. but first do clean the connection and make sure everything is plugged in all the way good luck
mrcraka
ah, can I swap the drivers seat with the passenger seat so I can at least adjust the seat and never worry about the power switch breaking ?? will the opposite seats fit ?? I imagine so though
xclusivez32
tt engine build
2004 gmc serria
if it is the switch i would just change it, its 2 screws and 2 connectors very simple job. but like stated above twice check the connections it might be something stupid that will save you the hassel of taking the seat out.
mrcraka
Hey can you or anyone pass me some links to where I can buy the power switch . I would really apperciate it
xclusivez32
tt engine build
2004 gmc serria
i bought mine off ebay, probably the cheapest place to get one
mrcraka
The cheapest switch I could find was 90 dollars. I hate how my forward backward doesnt work, but up and down does. Can anyone give me a link to a cheap working switch.
fchen
Car: 1994 300ZX Convertible
2001 MR2 Spyder
hi guys, i just got a 300zx 1994 today. One of the problem i noticed is the passenger side power switch. The seat will go forward, but not backward. The other switch is doing similar thing. The tilt would go forward and not back. Is this a typical switch problem ? If it is, then i simply go find another one. But i hate to buy it and to find out it is not the problem.
i noticed the two screws on the side of the switch; it's the only two screws i need to remove, right ?
thanks for any tips. It's my first day with my new car ... happy and excited...
trentonrk
Car: 1984 Nissan 300zx
Hello I have a 1984 Nissan 300zx. The driver's seat was not moving forward except on the right side, so i decided to remove the seat to find out what the issue was. It was a pain in the butt to get the back left bolt out it takes a little bit of playing around to get it out. All four bolts were 9/16 in. The front two came out quick. The right back was easy because i just used the motor to go forward and used a shallow socket to get it out. The back left bolt get a 9/16 in wrench and move the seat around at different angles to get it out. Once i had removed the seat from the car i found a mechanical wire much like a mechanical speedometer wire busted and wound up on its self. I hope that helps with the issue. Does anyone know what the part # is on that mechanical wire?
gowhoosh
Car: '94 300zx Twin Turbo
i am having a similar problem right now with my power driver's seat on my 94 300 TT. all the directions work except the backrest leaning forward, so i have a small clean garbage bin behind the seat to support it lol. i took apart the switch box on the side of the seat, and it is heavily corroded by some brown sticky substance and what appears to be battery acid. i'm going to attempt cleaning it with some vinegar and an old toothbrush. it *should* fix it. also, be careful when taking apart the switch box, as there are 2 ball bearings, 2 large springs, 8 small springs, and 8 little pins. i would recommend taking off the mount for it, turning it upside down, then taking off the cover. hope this helps.
