C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sat Aug 26, 2006 11:54 am
Not sure how relavant ths may be, but I'm running 05 Touring 18" Z wheels on my 95 Max. The front sticks out slightly, but given the opening and the stiff springs there, it has no issues. The rears look quite good, but due to the beam axle, there is no camber gain as both sides compress. I'm running take-off's from the G35 I had which are 225/45-18. I tried the Potenza S0-3's in the rear and they rubbed the sidewall on big bumps. The pilot sports have slightly narrower shoulderwith so it clears much better, but can still rub on big dips when I have rear passengers. I am also lowered on H&R springs so if your running stock springs, or stiffer springs(H&R's are very soft for the 95 maxima). Of course, this would assume the clearances are real similar in a 04 Max to the 95. I'm not sure what the Z32 wheel offsets are.
