Nissan 300zx front speaker
Lukasz86nyc
Car: 1990 nissan 300zx twin turbo
Hi guys im trying to upgrade front speaker i bought 6 inch audio pipe and z1 brucket then i try to put inside and is not. Flash i have to bend the plastic did anybody upgrade. Speakers any suggestions did you guys do any cuttings of the door
Destrto
Car: 1990 Nissan 300ZX 2+2 100K original Miles
I placed some foam padding behind the places where it didn't sit flush against the door panel. Worked fine for me.
Lukasz86nyc
Ok thanks im gonna try the only think. The back. Of the speaker is touching the door frame
everpresentnoob
Car: 1990 300zx Base. Manual and abused by previous owner....
I didnt cut my doors, however I did have to make a plate out of 3/8th inch MDF. It is way larger than my speakers and covers teh entire hole in the door after I removed teh factory buckets/mounts. It is large enough that I was able to get it to bend slightly as I bolted it to the door to seal. thin piece of the stick on foam insulating tape on teh back side sealed it to the door real well. if the speaker is touching the outer skin of the door you are going to have HORRIBLE audio issues with rattling and such. you could use foam on top of the mount to slightly raise the speaker from the mounts to get a little more clearance. Or make a thin trim ring to put between the speaker and bucket you bought to hold the speaker more to the inside of the car and keep it from hitting the door. Which ever way you go, dont forget to make sure it is sealed well.
