Ni2s4s0aSnX »
https://forums.nicoclub.com/ni2s4s0asnx-u27980.html
Thu Dec 08, 2005 6:01 am
You'll probably just need to do all of your routine maintenance that you would do, since the car has been sitting for a while. Some of these things are: Replace the spark plugs, replace the spark plug wires, check the fuel injectors and clean or replace them, replace the PCV Valve, replace your O2 sensor, replace your air filter, check all of your sensors to make sure they aren't loose or dirty or damaged (a loose throttle position sensor might cause the idle to fluctuate), change your oil, check all of your other fluids (transmission fluid, Radiator fluid, Anti-freeze, etc.), make sure you don't have any major fluid leaks. That's pretty much it, i guess. And if none of that works hit us up again. (It could be your timing)
