240Guroo@ProtoMotoring »
https://forums.nicoclub.com/240guroo-protomotoring-u51816.html
Thu Dec 07, 2006 9:09 pm
to remove ecu, it is located around feet area of passenger side. its that kick panel located on right bottom of glove box. there are two metal phillip screws around bottom of panel and 1 plastic phllip screw located near door jamb. remove 1 plastic screw from kick plate to lift off kick panel when removing. just slightly tilt up kick plate while fishing off panel to get to ecu. the ecu has one 10mm screw on top of it and one at bottom of it. remove ecu blue connector with 10mm wrench.
second, the diagnostic connector is located somewhere inside the area of the fuse panel located on drivers side kick panel.remove cover plate, feel around area on sides of fuse box. it will have a clear plastic shield over it.the connector is in rectangle shape.you will find it, they hide it pretty good.
email me of you get it going.
