Nissan 240sx 1989-1994 S13 Service Indicator and Warning Lights
spartanic
Click on the link to see the complete article with images check it out here: Nissan 240sx Service Indicator and Warning Lights (S13). Garage411.com
ENGINE TEMPERATURE GAUGE
Indicates engine coolant temperature. Gauge should register below the HOT range while driving.
SEAT BELT WARNING LIGHT AND CHIME
Light flashes on and off and chime sounds for about 6 seconds whenever ignition key is turned to ON position, unless driver's seat belt is securely fastened.
DOOR OPEN WARNING LIGHT
Light comes on when any of the doors is not closed securely while the ignition key is in ON position.
OIL PRESSURE WARNING LIGHT
If light comes on while driving, oil pressure is low. If this occurs, stop vehicle immediately and check oil level. If oil level is okay but light remains on, have system serviced as soon as possible.
CHECK ENGINE WARNING LIGHT (CALIFORNIA MODELS ONLY)
If CHECK light comes on while engine is running, a problem in the emission control system is indicated. Continued operation without checking the system may result in damage to engine emission components. Have vehicle serviced as soon as possible.
CHARGE WARNING LIGHT
Indicates that the battery is not charging properly. Check alternator belt tension. If belt tension is okay but light remains on, have the system serviced as soon as possible.
BRAKE SYSTEM WARNING LIGHT
Light will come on with the parking brake fully or partially engaged. If light remains on after parking brake is disengaged, or comes on at any other time, it indicates low brake fluid level in the master cylinder reservoir or the parking brake switch may be damaged. Add brake fluid as necessary and have the system checked and serviced immediately. DO NOT continue driving with BRAKE light illuminated.
ANTI-LOCK BRAKE WARNING LIGHT
Light is designed to come on with the ignition switch in the ON position and should go out shortly after engine is started. If light remains on or comes on while driving, it indicates a potential problem in the system and should be inspected as soon as possible. The regular braking system will still operate normally but without antilock function.
SUPER HICAS WARNING LIGHT (IF EQUIPPED)
If light comes on while engine is running, it indicates either low power steering fluid or a malfunction of the SUPER HICAS portion of the steering system. If fluid level is adequate but light remains illuminated, have system checked.
CRUISE INDICATOR
Light comes on as long as vehicle speed is being controlled by the cruise control system.
OVERDRIVE OFF INDICATOR
OD OFF light comes on when the overdrive switch is in the OFF position.
LOW FUEL WARNING LIGHT
Light indicates that the fuel tank is almost empty. Refill as soon as possible.
