Wc240 »
https://forums.nicoclub.com/wc240-u133792.html
Sun Jul 12, 2009 2:47 pm
first, download the FSM and stare at the wiring diagrams. take a break from that and chack all your fuses, and battery voltage. yes, of coarse there are relays that, if not working, will couse the car cot to start. Also, id check your wiring(factory and what you've done to the ignition/fuel pump) becouse you could have fried something, bad connection, etc. id deffinatly check the ALT 75 amp fuse. look in the fsm, start with the basics, then post up what you found/came up with.oh yeh, welcome
