Well I can’t get rid of it now it’s financed lol…casperfun wrote: ↑Fri Jun 09, 2023 8:01 pmNo, no, no!
That don’t sound right. Sounds like some cross wires or electrical haywire craziness going on.
Kinda reminds me of the humming when the cable wires are not shielded, you hear it in the speakers.
And this is with me keeping an open mind upon first hearing it.
And with my ocd, I would not stand for it by listening to that for the next several years.
Make dealer get rid of that sound or get rid of the Rogue.
Unacceptable. Bad craftsmanship or whatever.
Dump that rogue and say bye Felicia!![]()
I think you misunderstood what Casper was saying. Your vehicle is under full warranty. Almost every Nissan – including yours - comes with a 3-year/36,000 mile limited warranty. Take you Rogue back to the dealership and have them fix it.
Interesting, how sure that this sound is the issue ? And this sounds come for me from the inside of the passenger front side… and if so have you found a fix for this issue?PowerslavePA wrote: ↑Mon Jun 12, 2023 1:17 pmYES, I know you have the Turbo, but that is the noise I hear from my Purge Solenoid.
VStar650CL wrote: ↑Mon Jun 12, 2023 5:45 pmI have to look this up when I'm at the shop on Wednesday. If they're using PWM on a variable solenoid for the Purge Control, then it may just be that they just chose a coil which needs too low a PWM frequency and the solenoids are noisy because of it. Direct PWM on a coil usually causes a hum, so as an engineer you try to keep it at 10 KHz and up where the vast majority of people can't hear it. But with a big, cheap coil clamped with a typical clipping diode, frequencies that high can make the coil uncontrollable because the back-EMF dissipates too slowly to let it release. So you can either get mechanically fancy to leverage a smaller plunger and coil, or you have to drop the frequency and risk it being audible. If that turns out to be the cause, it won't hurt anything, but there isn't much you can do besides literally put a sock over it.
Hey @davsikk - you mentioned you had a service visit scheduled.davsikk wrote: ↑Fri Jun 09, 2023 6:31 pmFor the past 2 month now my new Nissan Rogue Platinum 2023 has an issue.
Currently at 3700 miles only.
When accelerating anywhere from 40+mph there is a buzzing noise coming from the front right passenger side. Unsure why?
When accelerating gradually to higher speed there’s no buzzing sound but when accelerating instantly to increase higher speed there is a buzzing sound.
Possibly when turbo is being used that is when the issue occurs?
Anyone else have this issue or know of it ? Any suggestions.
I do have a service scheduled next week.
Hi, yes it was at the dealer for over a week.Hebrew Hammer wrote: ↑Wed Jun 28, 2023 5:30 pmHey @davsikk - you mentioned you had a service visit scheduled.davsikk wrote: ↑Fri Jun 09, 2023 6:31 pmFor the past 2 month now my new Nissan Rogue Platinum 2023 has an issue.
Did you ever have this looked at by the dealer?
Any results?
Will let the tech know, but to my understanding it only happens when accelerating just not sure how this connects with sound systemcasperfun wrote: ↑Fri Jun 30, 2023 7:20 pmI was kinda thinking something with the sound system earlier, maybe you could try an Anti-interference High-Frequency Ferrite Core Choke Cable Clips on the problematic wire, or whatever was loose.
I use to have them on my speaker wires in my recording studio to help prevent buzzing in my speakers.
My 2 cents.![]()
Below is a link to the sound:
https://1drv.ms/v/s!AtHXMTlhSY85gYNwgZnv22BPhxX5SA
