lowkeyneon wrote:well im 99% sure its not the cas because that is brand new. and does the ignition amplifier the same as the 240's? and it dont really have a check engine light, its a 92. but i do notice the same light that comes on when you set the e-brake also comes on once in awhile while driving, and i assume its the same as the check engine light for that year.
That's the float sensor in your brake master cylinder, top off your brake fluid.
Have you tried resetting the computer to wipe any corrective measures that have built up over time? If not, you just disconnect the battery for about twenty minutes to restore the defaults.
