nissan 2.5 coupe top speed?
All things Altima Coupe.
infused305
Car: Nissan A/C 2.5s w/cvt fully loaded
The highest i have seen 2.5 coupe go is 110, has anyone surpassed 110mph. the fastest i have gone is 103 but have yet to floor it.
kanejuice
Car: 2008 Altima Coupe 2.5s - CVT - Radiant Silver
its 112mph or 113 mph my thing reads 112mph so.. yea...but the bullydog tuner should remove it
Zerep
Car: A/C 2.5R
your tires are rated at 115 i believe so if you do take off the limiter please change the tires!!!!!! dont want any one to die cause at those speeds i really doubt you survive a blowout
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Welcome to NICO!
Try not to wear your newb-ness on your sleeve...
Going that fast on the road isnt wise, and if you are on the stock tires, good luck!
kanejuice
yea.. if u attempt get better tires...and take it to a track for fun 8\
vonivo
Car: Altima Coupe 3.5 with all the goodies
Zerep wrote:your tires are rated at 115 i believe so if you do take off the limiter please change the tires!!!!!! dont want any one to die cause at those speeds i really doubt you survive a blowout
please do...or we'll be reading about your obituary.
Oh and Zerep the tires wont blowout at the speed listed but the car will become unstable around the max tire rated speed. Not to mention the 08 3.5 and 2.5 tires that came from the factory were complete junk and not trustworthy at any speed. I replaced mine be4 i even left with my car when i bought it.
lilojoj
oh man im lucky then. I went 140 on my stock tires. good thing nothing happened
vonivo
lilojoj wrote:oh man im lucky then. I went 140 on my stock tires. good thing nothing happened
you have a 3.5 with V rated tires...V rated tires are stable up to 149 but i wouldn't recommend it on the stock tires they are scary cr@ppy bad. http://www.tirerack.com/tires/...ing=T
Hussain
Car: 08 Altima Coupe 3.5se CVT
2.5 is limited to about 110 but with no limiter (like the altima coupes in the middle east) it can do i believe 145 or 140 MPH
johnnyplano
Car: '08 Coupe
Speed limiter on a 2.5 is set at 113mph because the stock tires are rated at 115mph. Nissan doesn't want a lawsuit for allowing their vehicle to exceed the limitations of the tires they chose to put on it stock. If you use the Bullydog tuner, you had better set yourself up with some good z rated tires. Seriously. At unsafe speeds, you owe it to yourself to make sure your vehicle can handle it. And you owe it to the rest of us to make sure you can handle your vehicle.
That being said, 113 has been verified as top speed stock. ;-)
(I'll let you know the "real" top speed after a Bullydog and a few track runs!)
Zerep
Car: A/C 2.5R
i by unstable you mean what... shaking of the steering wheel.... regardless it is very bad.
mastersapo
Car: 2008 2.5 S Altima Coupe 6MT
I have been above 115 with the manual transmission stock...
Rob.Vegan
Car: 08 2.5S Altima Coupe 76 Datsun 280z (not running)
Mine tops out at 112, maybe 113 i guess
ReviT
Car: 2006 VBP Acura RSX-S
Definately 113
